Signs101.com
Go Back   Signs101.com > SOFTWARE • Open to All Members > Flexi
Notices
Flexi Flexi topics
Main Menu
Module Jump:
September 2010
S M T W T F S
      1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Signs 101 Merchant Member Directory
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 15,743 Entries 0
Members Entries
Threads 67,263 Reviews 0
Threads Reviews
Posts 738,686 Polls 197
Posts Polls
Content 16 Files 8
Content Files
Links 481 Ads 0
Links Ads
More...
  #1
Old 05-15-2007, 08:59 AM
Andy @ Easy Signs Andy @ Easy Signs is offline
Preppie
Question FlexiSign 8 - PDF Import Problems
Hi Everyone,
Just wondering how you deal with the frustrating problem of importing PDF files into FlexiSign Pro 8.
Nearly all of the files we recieve are from graphic designers who love to use transparencies & drop shadows. Most of the time these will not come in correctly.
Does anyone know if there is an update of any kind or plans for an update to Flexi to solve these import problems?
To get around this I generally open the PDF files in photoshop at 150dpi to the correct size they will be printed and then save them as a JPEG file at the top quality. I then import the the JPEG into flexi and it prints really well. This is however a long frustrating process to do over and over.
I would appreciate your comments!
Cheers,
Andy
  #2
Old 05-15-2007, 10:13 AM
Sign-Man Signs
Guest
Posts: n/a
Andy,
I use the same as you. I just updated my Reader 8.0 and don't have anymore problems. Hope it helps.
  #3
Old 05-15-2007, 12:23 PM
zmatalucci's Avatar
zmatalucci zmatalucci is online now
Every time I export as a pdf with transparencies, I get an error and the flexi program crashes?
  #4
Old 05-15-2007, 12:44 PM
thewood's Avatar
thewood thewood is offline
Master of Arts
Andy, I use the same method. I save as a tif with the icc profile embedded (anywhere from 72-300ppi depending on the application).
  #5
Old 05-15-2007, 01:45 PM
Castek Resources Castek Resources is offline
College Junior
Are you importing the PDF into Flexi in order to print it through the RIP?
  #6
Old 05-15-2007, 02:03 PM
mbarden's Avatar
mbarden mbarden is offline
College Junior
I am having the same problem. I import the pdf's from design houses, the sahdows and other effects become blocked (as in square). Very frustrating as I then have to open in PhotoShop and then save as a .psd file.
Anyone else run into this?
Mike B
Big River Sign Co.
  #7
Old 05-15-2007, 02:11 PM
Rodan68 Rodan68 is offline
College Freshman
I have the same problem. I usually open the pdf in Acrobat Professional and save as a 150 - 300 dpi RGB TIFF and print that. I like opening in Acrobat because most customers are looking at the file in Reader or Acrobat and this method seems to match the colors they are seeing more accurately. I think you can tell customers to flatten the transparencies before saving as a pdf but a lot of them wouldn't know how to do that. I would also like to know if there is a certain pdf version or Illustrator version that Flexi would open correctly 100% of the time. Any one know?
  #8
Old 05-15-2007, 04:27 PM
College Junior
Have you attempted to open the PDF directly into Production Manager? I do this often, and it's possible to scale the file to desired size right in the Job Properties window of Production Manager. Of course, you cannot edit the file in Production Manager.
Acrobat PDF files generally will open and print properly using this workflow, and not import correctly into Flexi.
Bob
  #9
Old 05-16-2007, 05:45 PM
Preppie
Thanks for you comments!
I tried importing a PDF directly into Production Manger a while ago and the file came in much better but was still missing something. However I tried with the new file im working with and it came in perfect! Thanks for your help.
My only problem now is that there is a gradient in the design and for some reason the rip decides to only make 4 different huge bars of shades of grey instead of a nice smooth gradient.
I have the gradient rip selection set to "Super" or whatever the highest one is.. Has anyone had any problems with this?
  #10
Old 05-28-2007, 11:59 PM
jbq7448's Avatar
jbq7448 jbq7448 is offline
College Freshman
The best method that I have found is to open the pdf in Illustrator, make sure all fonts have been converted to outlines and then save as an Illustrator 8 eps. I have found that you will run into problems if native illustrator ai files have been used in the artwork - they will reverse out. Tell your clients to use eps's for placed vector artwork and you'll be ok. If you try to save fairly complex artwork at banner sizes as a tiff or a psd you can sometimes bump up against file size limitations.
  #11
Old 05-29-2007, 12:02 AM
jbq7448's Avatar
College Freshman
Forgot to add - the black boxes that Mike B describes are where the designer has placed native Illustrator ai files in the artwork.
  #12
Old 05-29-2007, 09:18 PM
Bobby H Bobby H is offline
Bachelor of Arts
You get the best results by opening the PDFs in Illustrator and then "flattening" any of the live effects -either by using the "expand" command on specific objects or just selecting everything and using the "flatten transparency" dialog. Sometimes you need to go back and use pathfinder commands to clean up overlapping objects (common problem in expanded line strokes). That's pretty important if you're taking the artwork to a vinyl cutter.
Once you're satisfied with how the artwork looks flattened/expanded then you can save it in Illustrator format and have an easier time getting it into Flexi or various other programs.
__________________
Friends help friends fight font murder.
  #13
Old 08-22-2009, 11:19 PM
luggnut's Avatar
luggnut luggnut is offline
oops
Last edited by luggnut; 08-22-2009 at 11:20 PM. Reason: didn't see how old this thread was
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
All Content Copyright © 2003 to 2009 Signs101.com. All rights reserved
TERMS AND CONDITIONS OF USE
All posts and other information available at Signs 101 should be viewed as the opinion only of the poster. No claim is made that any information is accurate. As such, each reader should not rely on any information available here as accurate and should independently verify such accuracy. In addition, no claim is made that posts made here will be free from profanity, obscenity, rude, hurtful, libelous or insulting opinions of the poster. Such posts should, however, be reported to an Administrator for review.
Neither the owners, employees, officers nor directors of Signs 101 shall be held responsible or liable under any legal theory for any loss or injury resulting from any post, information made available, policy, action or lack of an action at Signs 101. Your use of this website is your acceptance of these terms and conditions of use.
