[+1-888-272-8868] How to Install My Canon Printer to My Computer
taylorcarr
Install my Canon printer to my computer (Call USA/CA: +1-888-272-8868) is usually a simple process, whether you're connecting it via USB or setting it up wirelessly. Canon provides straightforward setup tools and drivers that work on both Windows and macOS systems. This guide walks you through the steps to get your Canon printer up and running on your computer in just a few minutes.
Step 1: Unbox and Prepare the Printer​
Before you start the installation, make sure your Canon printer is fully unpacked and ready:
  • Remove all packaging and protective materials
  • Plug the power cord into the printer and a wall outlet
  • Turn on the printer using the power button
  • Install the ink cartridges and load paper, if required
  • If your printer has a touchscreen, follow the prompts to complete initial setup
Step 2: Choose a Connection Method​
You can connect your Canon printer to your computer in one of two ways:
A. USB Connection
This is the simplest method and is ideal for home users.
  1. Plug the USB cable into the printer and your computer
  2. Your computer should automatically detect the printer
  3. If prompted, allow the system to install necessary drivers
  4. If it doesn’t auto-install, continue to Step 3 to install drivers manually
B. Wireless (Wi-Fi) Connection
This allows your computer and printer to communicate over your home network.
  1. On the printer’s control panel, navigate to Wi-Fi Setup
  2. Choose Wireless LAN Setup, then select your Wi-Fi network
  3. Enter your Wi-Fi password using the printer’s keypad or touchscreen
  4. Once connected, proceed to driver installation
Note: If your printer does not have a screen, use the Canon PRINT app or a USB setup method to connect it wirelessly.
Step 3: Download and Install Drivers​
To ensure full functionality, download the latest Canon printer driver and software:
  1. Go to https://www.usa.canon.com/support
  2. Enter your printer model in the search bar (e.g., Canon PIXMA MG3620)
  3. Select your operating system (Windows 10, Windows 11, macOS Ventura, etc.)
  4. Download the recommended Full Driver & Software Package
  5. Run the installer and follow on-screen instructions to complete setup
During the installation process, you’ll be asked to choose between USB or wireless setup—select the one you’re using.
Step 4: Set the Printer as Default​
After installation:
  • On Windows: Go to Settings > Devices > Printers & Scanners, click your Canon printer, and select Set as default
  • On Mac: Go to System Settings > Printers & Scanners, select your Canon printer, and set it as the default
Step 5: Print a Test Page​
Once installed, open any document or photo and select File > Print. Choose your Canon printer from the list and print a test page to confirm everything is working properly.
Final Tips​
  • Restart your computer and printer if you run into issues
  • Always use genuine Canon drivers to avoid compatibility problems
  • For wireless printers, ensure your computer and printer are on the same Wi-Fi network
Conclusion
Installing your Canon printer to your computer is easy when you follow the right steps. Whether using USB or wireless, you'll be printing in no time with just a few clicks and a quick driver installation.
