Vector Vinyl
So i’m using a unique material (it’s literally the material that i wanted this printer specifically to print on). First six months it works great but over time ONLY this material starts messing with the printer in a couple horrible ways.
Important point: it’s very shiny. the back is normal white. not plastic.
First, if i load assisted half the time it’s clear something is wrong. It’ll feed backwards fine but not forwards. When i try and print it won’t feed forward at all and the print will just stay in the same area the whole time.
I’ve tried disabling OMAS but it’s not fixing the issue.
Also sometimes if i load manually. When it’s starting to print it will unload the material right before the printing starts and then the printer will start printing with no material in it. Again it only happens with this material.
I know OMAS scans the back. Is there another sensor that scans the front that might be the issue? I’m sure it has something to do with the material being so shiny but again it worked for six months no problem.
Would love some help. HP could only tell me to disable OMAS.
