8600 cant cut holographic
jwlllpl
When we cut foils or metals we make sure the middle rollers are set on medium pressure and outer ones are on lowest setting. We slow the plotter speed down to 10 using the blade for this material type. Keep the runs under three feet so the weight does not become an issue. Some of the material backers are can be slippery so we have also pre-masked the backing to keep from sliding. Hope this helps.
