I had a CE3000-120  3 rollers.
I got 10 years of heavy use out of that cutter. Was a fantastic plotter
for not being an FC.
If you bought that 5000 new and run it good every day, you could easily be at end of life.
Take time to clean the grit roller. I use masking tape to pull up debris stuck to the roller
 and the denatures alcohol and a stiff plastic brush from Home Depot  Paint dept. less than a buck.
Grit roller should now have a more pointed bite to the touch.
If prob persist get 3 inspect the rollers (Buy OEM)
If Prob persist, remove the 3 new rollers and save them.
a 5000 could easily be at end of life, and if this is the case.  Keep the Stand and Mounting Plates.
You can Retrofit a trimmer table to these stands.
The stands are very expensive for what they are and if the stand has the 1" Tube rollers for the
roll vinyl even better.
Pretty much all trimmer tables do not support a roll  of film and is why these stands are
valuable.  If your stand has a media catch basket,,,,,,Double Down.
Anyway I hope cleaning the grit roller or new OEM Wheels solves your issue.
If not the CE 7000's  look to be a big step forward for graphtec.
It makes yo money,, never be afraid to reinvest into something that makes you Money.
Meaning dont buy Used. You never know who did what to the machine.
To find Used that was not used is rare, very rare.
