ledbe
The addressable LED sheet lights are thin, flexible, bendable, cuttable, and linkable.
Can be easily installed or linked as backlighting for marble countertops, display boxes, signs, and DIY projects.
The 5050 LEDs are arranged on the dual-layer PCB board, and the WS2812 ICs are built-in and allow for addressability.
Easy to connect to SPI controller to achieve hundreds of dynamic lighting effects or animation displays.
product link: https://www.ledbe.com/digital-individually-addressable-cuttable-rgb-led-sheets
Features:
Features:
- Type: Addressable Cuttable Light Sheets
- Model: LB-5050-100-IC
- Size(L*W): 250*250MM/0.98"*0.98"
- LEDs: 100PCS 5050 SMDs
- IC Type: Built-in WS2812
- IC QTY: 100PCS
- Color: RGBIC
- Working Voltage: DC12V
- Current: 1.08A
- Power: 13W
- Luminous Flux: 20LM/LED
- Wavelength: 620-625nm(Red), 520-525nm(Green), 465-470nm(Blue)
- Beam Angle: 120°
- Flexible, Bendable, And Cuttable
- Back With Double-sided Adhesive Tape
- Surface With Screw Holes And Multiple Connectors
- Waterproof Level: IP20 Non-waterproof, IP54 Waterproof
- Storage Temperature; -20℃-+65℃(-4°F-113°F)
- Working Temperature: -20℃-+45℃(-4°F-149°F)
- Certifications: CE, ROHS
- Lifespan: >35,000 Hours
- Warranty: 3 Years Replacement
