Adjusting the density
MangoPRI
Too adjust the density, is it adjusting the number of passes? Or is there another option?
the lower the passes, the more ink that is put out in each pass for example?
Also, does this effect the resolution? Lower passes appear to be more bandy.
I guess lower passes mean more speed too!
Thanks,
Chris
Pauly
Printrade.com.au
more passes - higher resolution. doesn't mean more density.
You can make a higher density print inside the rip. depending on your rip.
