I am about tapped out troubleshooting this thing. I figured maybe one of you have seen a similar issue and could point me in the right direction
JFX200-2513
When I go to do an air purge on this machine, regardless of which head or quadrant of the subtank, all of the ink drains out on the second or third purge. The tank appears to be refilling but not quick enough or perhaps the vacuum or pressure is not correct or air line leaking somewhere?
What I have done:
Any help would be greatly appreciated!!
JFX200-2513
What I have done:
- Replaced the air pump with a supposedly good working used one
- Replaced the solenoid air valve in the carriage (again with a used one – I will try swapping one out of another machine today to confirm the used one not bad)
- Readjusted the pressure and vacuum to spec.
- Replaced subtank and subtank sensors
- Bypassed air filters on top of subtank to rule out dirty/clogged filters
- Checked that ink pumps working correctly
