PrintItBig
Hi,
We've just acquired a Roland printer and are literally printing our first job on it at the moment
This is our first solvent or eco solvent printer so it's a bit of a learning curve.
The problem we're having is that when printing solid dark colours at low pre heat / post heat temperatures on a certain type of vinyl we want to use, this creates a slightly mottled orange peal effect. If we bump up the temperatures to the maximum setting (45, 50) this completely disappears. There doesn't appear to be any adverse effects to this other than a very very slight cockeling of the vinyl. This is very slight and can only be seen at certain angles.
My question is, is there any reason not to bump up the temperatures like this? Should we be sticking to lower temps for some reason? Do the higher temps affect the life of the vinyl or anything like that?
Thanks.
This is our first solvent or eco solvent printer so it's a bit of a learning curve.The problem we're having is that when printing solid dark colours at low pre heat / post heat temperatures on a certain type of vinyl we want to use, this creates a slightly mottled orange peal effect. If we bump up the temperatures to the maximum setting (45, 50) this completely disappears. There doesn't appear to be any adverse effects to this other than a very very slight cockeling of the vinyl. This is very slight and can only be seen at certain angles.
Thanks.
