www.signs101.com
The only reason I could think it wouldn't open it it would be if it was created in a newer version than what you have. Normally you can simply open the file by changing the option when opening from "All Readable" to "All Files" and it will open from there. I still have some really old VE files I open on occasion. VE is the same format as FS, but just rebranded as Signwarehouse's software brand (Vinyl Express). I used it for the first few years when I started, eventually moving over to Flexi 7-point-something. If no luck, you can PM me and we will figure out a way for you to get me the file and I'll see if I can open it in a newer version of Flexi I use.I tried my flexi 7.0 and that wont open it, someone said 8.0 would ?
I did try changing the extension fs but still didn't work
Thanks, I had an old computer with Vinyl Express on it that someone gave me and was able to open it thanks everyone for your help !!The only reason I could think it wouldn't open it it would be if it was created in a newer version than what you have. Normally you can simply open the file by changing the option when opening from "All Readable" to "All Files" and it will open from there. I still have some really old VE files I open on occasion. VE is the same format as FS, but just rebranded as Signwarehouse's software brand (Vinyl Express). I used it for the first few years when I started, eventually moving over to Flexi 7-point-something. If no luck, you can PM me and we will figure out a way for you to get me the file and I'll see if I can open it in a newer version of Flexi I use.
