Need Help Arizona 2380 GTF - Fotoba Mark issues.
Shawnski
We've been having issues printing panels with Fotoba marks. The panels center when we specifically justify them left. We're printing on an Arizona 2380 GTF using Onyx Rip 21. Anybody out there know why this might be happening?
SignMeUpGraphics
Super Active Member
As Pauly mentioned above... the Arizona will center anything sent to the RMO. You could fudge it by mounting the roll off-centre if you really need to, but it would be job-width dependent.
Pauly
Printrade.com.au
Yes on the RMO. It seems that Canons software is over-riding how we are justifying in ONYX
Yep. I had this issue too.
Can be annoying.
As Signmeupgraphics mentioned.
Offset the roll.
I've done it a few times. It works.
When im printing something that's smaller that the fotoba will struggle to slit, i'd print the start of it.
Stop it
mark where the fotoba mark is
unlock the shafts
slide the stock across till it's near the end and lock it back up.
Shawnski
Can be annoying.
Offset the roll.
Stop it
unlock the shafts
Yes, definitely a bit annoying.
That's clever, thank you
