Question Avery V4000 Reflective Yellow: Anyone Print on it (with a Gerber Edge)?
jochwat
Graphics Department
Hi there. I'm trying to tighten up some of our stocked digital materials, and have gone through the data sheets for many of them, causing my brain to become numb. In the Avery Dennison V4000 Reflective Vinyl spec sheets, it's stated that the White version is printable... implying that none of the color varieties are printable. Has anyone printed on V4000 Yellow Reflective with a Gerber Edge machine successfully?
Thanks!
Jburns
well - on a yellow vinyl you can print black. Only way to print other colors on yellow is to print a heavy white underbase, and results may not be that great.
jochwat
Graphics Department
Black was indeed the intended print color.
Jburns
Is the texture smooth like their other vinyls- you can check the spec sheets and make sure its thermal printable - but if the white is - the other colors should be also.
