Best practice for prioritizing and batching for best use of material/time
ProdPrintMan
I have been trying to figure out the best way to explain what I am trying to accomplish.
Essentially, we are looking at our process trying to figure out how to best utilize material when sending files to print.
more detailed explanation:
We are trying to be more lean and cut down on waste by batching and nesting jobs that are printing together on the same 4x8 ACM and same laminate, for instance. The thought at one point was to use hotfolders so when PrePress sets up the print file, they put the pdf into a hotfolder specific for that printer/material/laminate. However, once a pdf drops into the hotfolder, it is in the RIP (Onyx Thrive) for that printer, so if someone else drops a pdf for same printer and material but different laminate, that pdf is in the same rip area as the other jobs, making things a bit muddy in the rip.
My gut says this is a scheduling thing mainly, and to utilize the scheduling/calendar available in the software we are using (or are going to be using soon, which is switching from Control to Mothernode).
Anybody have any suggestions or ways they best organize how to batch to best use material and time?
Thanks!
PrakashTaggIQ
We ended up splitting it into two steps instead of letting the hotfolder do the grouping. Prepress tags each job with printer, substrate and laminate when the proof is approved, and the schedule view groups by those tags. Once per shift someone builds the gang sheet from that group, nests it, and only then drops one combined PDF into the hotfolder. That keeps the RIP queue clean because every drop is already one sheet, one material, one laminate.
The other thing that helped was a cut off time. Anything approved before 11 goes on the afternoon batch, and true rush jobs are the only exception.
If Mothernode lets you add custom fields or job tags, set those up during the switch so the batching filter works from day one.
