Cannot open eps file
trusso
Hi,
Does anyone know why I wouldn't be able to view /import/open an eps file in my signmaking software.
The customer is ready to go to someone else to have their sign made of their logo... I can't open it. I also have a pdf, eps and jpg version but my software won't let me import or autotrace them.
Any ideas.
I attached the jpg version of the file, it wouldnt let me upload the eps file....can anyone else import it and autotrace it? Do you think it needs saved in an earlier version? I asked the designer to do that but they haven't sent me another one and the customer is anxious.
Thanks so much!
Tracy
trusso
btw - I have flexi/lxi software.
Do you all think I need an adobe product also, in addittion to my signmaking software? And if so, what do you recommend. I have a small shop that does mainly typography (font) work for interior signs with the removable vinyl (631).
Thanks!
The Big Squeegee
Long Time Member
Welcome from OK
eps files are a cantankerous lot. How you work with it depends on the program that created it. If it won't open using the "open" command then try to import it into your program. Sometimes it's the other way around.
Good luck!
trusso
what do you mean? That is the fonts they used? Thanks!
I could redo it, but it still wont let me autotrace (vectorize?) the flower. When I try to it says, "Only RGB Format can be autotraced." :(
trusso
Thank you - I was trying to import so I tried open and that worked, however it says there are no cuttable objects and if I try to autotrace/vectorize it it says "Only RGB Format can be autotrace" :(
Any idea how to get around that or why it says that...?
Thanks!
trusso
because I don't know how :( I'm so new to all this graphic/design stuff - if that will work, I will. Any tips on how to do that?
Jester1167
I suck at Flexi and spend as little time as possible in there.
But, when learning new software, when trying to do anything with an element double click on it and see what happens. The right click on it and see what happens. Most software will have the most used built in shortcuts right there. Next click on an obect and use your menus.
I would suggest reading the manul, viewing this site (www.givemehelp.com) and taking a class from Mark Rugen. Knowing what you can do is half the battle. Flexi does alot of things well but 10 years of Corel and I can't stand Flexi.
thewood
What version of Flexi do you have? It sounds like you will need to save the .eps as an earlier version in order to import it into Flexi. Look into buying Adobe Illustrator for conversions like these.
In order to convert the bitmap into RGB mode in Flexi, go to Bitmap>Color Mode. Although, the easiest method would be to convert the supplied art into an .eps that Flexi will import.
Jackpine
An eps files can be vectors, bitmaps or both in the same file. Try to copy and paste into your design software. I would have a problem with the customer not sending a good quality file. I would recreate the file since the image is simple and Shovelhead gave you the fonts to use.
