Need Help Can't Connect To Epson S40600
Goatshaver
I was having internet issues and reset my network setting on my laptop now I cannot connect to my Epson S40600. The setup tool doesn't detect it either. I'm stressing now as all my equipment seems to be disconnected now.
netsol
do you know the ip of the printer?
are you connected to the internet now?
do you know how to check thecurrentbip of yourvlotop?
run>cmd>enter
ipconfig. first number diplayed for the first active adapter
are the 2 ip's first 9 digits the same? (ie 192.168.1.xxx)
Goatshaver
run>cmd>enter
No the first adapter is: 169.254.253.xxx
I'm going through a switch but I don't remember having this issue when I set everything up.
netsol
invalid address. probably switch problem
power off modem, router and switch
wait 10 minutes
power off pc
power all back on
power pc back on
if still a problem, pm me
iwill talk you through setting static ip ip necessary
while
GiveUsSigns
I had the same problem with my S80 as it lost connection a couple days after install. Called the tech that set it up and he had to go in an do his special tech things to get it back online.
I know that doesn't help, but it happens.
cshook
I have the same problem, ever since I upgraded my modem.i have to reset it if I want to print anything.
Goatshaver
All I had to do was set a static IP for my Ethernet. My internet is wireless so it didn't have any affect on that.
