Change size of Reg Marks in Flexi 8.1
Rat_Fink
Hello - I recently switched to Flexi 8.1 from 7.6.
My old version of Flexi made the contour cut reg marks approx ½" or so & this newer version makes them approx ¾".
Is there any way to make these smaller? I am using Graphtec Type 1 Automatic as the setting.
Mike
thewood
I'm not sure how to change the size of the marks. On our Mimaki plotter, you can set the size of marks to detect. Ours is set to 10mm which is the size that Flexi prints for Mimaki registration.
Noonan
I believe you have to do it at the plotter.
For the fc8000...
Menu - 2 (arms) - downarrow (pg 2 of 4) - Mark Size
good luck.
Rat_Fink
Thanks for the info, but I am not trying to adjust the scan area (at the plotter)...
I am trying to reduce the size of the printed marks that Flexi prints.
In my old version - they were approx ½" & in the new version, they are approx ¾".
Mike
eddesign
marks
Go to Rip and Print then in upper left hand corner click on properties.Then default job propreties will come up.Then go to labels and marks and there you will see it.They like to move things around who said change is good
