Channel Letter Clinching Machine
SfSD
Taloc Clinching Machine
This is a very well built and heavy Clinching machine. It works off 110VAC and is a cam driven mechanical clinching process. It is faster and more reliable than Air Over Oil Clinching process.
Cut from 4” thick steel plate provide less deflection for longer tooling life. Allows for easy adjustments to keep tooling perfectly concentric which assures a consistently strong lock and long tooling life. Modular Mechanical Head. Complete head is wedged into frame section and built from interlocking components. CNC machined from high grade material for precision strength and durability.
Oceanside CA
Frank
760-840-1350
frank@s4sd.com
