Doing it yourself Pros: Saves Money, You learn a little bit about how your machine works which helps for future fixes.
Doing it yourself Cons: It will take longer for you to do it than a tech, if you mess up you are responsible for the cost of more repairs
At Solventinkjet.com we will sell you the head and help you if you get stuck during the installation process. You can also call and speak with out techs before your buy or install to make sure you are comfortable with the process. We also provide the installation manual.
As long as you unplug the machine and let it electronically discharge before working on the machine, avoid getting ink on the electrical parts and plug cables and dampers perfectly straight in, you will not do any damage to your machine.
