If you know anything about ink jets, you know if you don't have the correct profile, you'll have a hard time hitting specific colors, ink limits/over saturation, delamination, and that's just to start.
Gerber goes to great lengths to profile (heat/speed/pressure) each of their foils with each of their materials. Using third party ribbon is usually a cost savings when you purchase them. But there is greater waste in both time and material when you have to experiment with different profiles or settings to make your third party ribbons work.
If you are always printing on a particular material, and you find that a third party foil works well, it is tempting to go for the savings. But if you are switching between different materials for different jobs, it will cost you time and material to find the right settings
Turn-key is sometimes more expensive, but do you have more time or money?
Once you experiment and find the right settings for your special combination, you can save those settings in GspPlot. And as long as you always use the media and foil color that you saved, it should work great. Remembering all the combinations you save will take some organization such as saving it in the same folder with the job.
Doug Goodloe
Gerber Specialist
PS: Tamiya has the foil core size backwards. Edge 1 & 2 foils are on 1" cores, FX are larger. You can use Edge 1 & 2 foils in the FX with adapter caps, but you can't go the other way. GSP, Duracoat, and Z9 foils are in stock all the time at
www.ShopGMS.com.
