Rat_Fink
Graphtec FC9000, Mutoh XpertJet 1641 SR Pro and Flexi 22.
Until a bout a week ago, this setup has been flawless.
Now, print files are randomly cut approx 1/4 off (always shifted toward the back of the cutter).
These are files that I have printed numerous times in the past and I have not changed any setting at all.
I wouldn't think it would be a calibration issue since this happens randomly.
In the photo attached - the job on the left has the cut line shifted approx 1/4 to the right (the way it is fed into the cutter is 1/4 toward the back) and the job on the right is a reprint of the same file and was cut normally.
I do not know if the problem is with the printer, the software or the cutter. when it does happen, the distance and direction of the shift seems to be the same and is the same throughout the entire cutting area. It's not like it is correct on the beginning then drifts toward the end of a long cut.
The only thing that might have been done between the jobs is a reboot of the devices - but as mentioned, this has never happened before approx 1 week ago.
