phototec
Ok folks I just started doing some rhinestone T-shirt designs and you need to cut the small circles in some template material. I'm using Illustrator for the artwork and Cutting Master2 to send files to the Graphtec FC-7000, however the small .127" circles are not completely cutting the circle I think the start and end points on the cut is just touching, not over cutting.
Doing research on a rhinestone templates, they recommend setting the cutter to OVER-CUT when making a circle, so the blade goes past the starting point a little after cutting the circle.
Anyone know HOW to make this adjustment, on the plotter or in CM2?
Thanks for any help, guidance, or suggestion....
