Need Help D140 reading material size ?
Claytons
I recently pruchased a D140 and when I send a file to cut it reads the vinyl from side to side then unrolls the whole roll ( I assume for skew ) Is there a way of bypassing the second bit because I only cut small files so there isnt a need for the whole roll to be unwound.
I'm Cutting through flexi 12 if that helps.
balstestrat
Problem Solver
Yeah it's in the cutter.
I think it should only unload the amount of the width and then roll back to get it loose. But I only mean when you load the roll.
I guess you have some length query in the cutting software?
Claytons
OK maybe that happened and that's all that was left on my roll, I will look into turning off autoload for when I'm just doin small cut jobs, Thanks for your help.
