Double cuts?
The Giraffe
My SP 300 seems to be doubling up on the cut paths. The second seems to be about 1/32" outside the first. It doesn't happen out of X3 but happens when using Illustrator out of Photoshop.
All settings are hairline and test cuts on machine work well.
Any ideas?
Thanks in advance.
GK
sounds like there are two cutpaths it is reading and one is slightly larger than the other. Are you creating the contour line in PS and importing it into Illustrator?
3CGraphics
happens to me when I import between programs - somehow 2 outlines get created or imported - can you break it apart - then click once and delete? I bet there is another exact path there.
Fred Weiss
This is an ongoing problem with Adobe Illustrator files which is addressed by a freeware Javascript you can download HERE.
The Giraffe
Perfect.
That's the kind of answer that makes me want to buy Express Clip Art files.
Thanks Fred...and others.
Now if I can just get my sheet cutter working.
