Need Help EFI H1625 : blurry unclear text and or fuzzy print quality
rhill
Hello, I am experiencing some blurriness around the text and lettering. (Please see attachments)
I have tried soaking the print heads over the weekend and today flushed the black ink, as that usually resolves the issue. I'm not sure what else I could try.
Any thoughts?
Kreate !nk
Most likely ink viscosity change..is it old ink? or (ink used in summer conditions can change viscosity rapidly). Also media static can cause that issue it would likely be print-wide, not just certain colors.
AlsEU
If you print unidirectionally, do you see any change? Try also to print the same file on the paper and check the results.
