Engraved Steel Tags
rjssigns
I need a source or three that can engrave 16ga or 18ga mild steel tags with a client logo. I have the vector art. Size: 1.25" x 2.5" Quantity would be anywhere from twenty to several hundred.
My laser guy all of a sudden says he can't do it after telling me it wouldn't be an issue.:frustrated:
Moze
These guys do great work and are simply great to work with. They've been around since the mid-50's I believe.
If you call, ask for Randy and tell him I referred you, please.
rjssigns
Thanks for the sources. Doesn't look like they can do what I need. (see attachment)
I'll call them to make sure.
royster13
Are these multiples of the same design?....If so, maybe ask a lapel pin supplier to do something die struck....
Moze
Joyce can do it - I promise.
Forgot to ask - what's the diameter of the exhaust primaries (assuming that's what these are for)?
http://www.yellowbullet.com/forum/showthread.php?t=365261&highlight=chassis+tag+henline
Furo Racecraft is on that msg board....7secondmalibu is the guy you need to contact...
edit....here's the guy's #...his name is josh - 419-467-0959
I was on that site until low 11's became slow. :noway:
