.eps file to LXI master
Si Allen
Click on File, Then click on Export, when a new window opens, select where you wish to save on your hard drive, also select EPS in File typs then clicl OK.
From LXI, import it from your hard drive.
Steve G.
Yes, I've had less than good luck with eps files and lxi and flexi.
I usually always get them to an illustrator file somehow and they'll get into flexi (lxi) with litle or no problem. Either open the eps in illustrator and save as an ai or export to an ai from corel.
steve
Fred Weiss
You need to have the Corel user export as an earlier version of EPS. I recommend going all the way back to version 3.
