Need Help Epson Dx5 Magenta firing issue
aji.p.vijayan
Hi there,
dealing with this issue for quite some days now unable to sort it out..
Colorjet Aurajet Series II machine with dx 5 print head..
Captop & dampers replaced the problem still remain.
Before printing the test print is good.
During Print - After some minutes lines on prints then no color.
Stopped print and make another test print magenta missing, perform a powerful cleaning test print good again.
Anyone had ever encountered this issue..
regards,
Ajith
Andre@Beith
Hi there,
regards,
Ajith
Hi Ajith
Sounds like your magenta ink line. Could be the tubing as you print its getting air. had it before when you do your clean and nozzle print all is fine but when you start printing colour dissapears. had a hairline crack in the ink tube
aji.p.vijayan
Hi Ajith
Thanks for the advice Andre.
That problem is solved, now have another one that, magenta ink is coming out from cyan needle while doing the manual cleaning.
If you'r flushing cleaning solution through the head with a syringe and you push into one nozzle and it comes out of the other one, the head is internally damaged. Every channel should flush through only it's path.
Hot Vinyl
Hot Vinyl
Hi there,
regards,
Ajith
I have a mutoh 1204 with a dx5 print head. The print head is only 2 weeks old. I stayed today having the issue of prints then the color goes away. It is on the yellow. How did you fix the magenta?
