Epson S40600 Orajet 3621 buckling
soggywinter
I'm having a chronic issue with Orajet 3621 3mm media buckling and causing head strikes. I've tried the usual playing with tension, suction, and setting the platen gap at 2.5mm. Can anyone recommend media profile settings for the Epson S-series? thanks.
soggywinter
Turning off the heaters seemed to resolve the buckling.
Current settings
Platen Gap: 2.5
Suction: 8
Tension: 4
All three heaters: off
Saturn
Your Ad Here!
The first two heaters are primarily there to soften things and make the material more receptive to the ink, and the last/front heater is there to help dry the ink. It shouldn't play any part in any warping/buckling or headstrike issues.
I'd try something like 108, 105, 120. If your material is more than 6-12 months old it could easily just be a little wonky from age. Fresh rolls will usually lay flatter than stock that's sat around. I've also seen material with too little heat, so it goes both ways. Trial and error!
  • Agree
Reactions: 1 user
WeFixPrinters.com
You can also try to slow it down, ink over saturation with some media can cause it to swell and buckle....Lower dpi, less ink.....The drying suggestions are more likely.
