exporting to pdf troubles with lines
msenjur
lattely im having problems with exporting pdfs.
it generate multipe nodes on curve by itself. It doubles it and it makes a object...
I use hairline thickness.
i have sam routine as always. pdf profile is the same as always. what is wrong???
Here is exported file
This is original file
im also having same problems with exporting only black outlines when doing come cutting files
GAC05
Quit buggin' me
Use a solid fill and no outline. Should give you a single clean path on the outline of your shapes
