ucmj22
I have always battled with our laminator since day 1. I never thought it worked right, but none of us had anything to compare it to. I use it alot for mounting prints to panels up to 4X8 in addition to laminating. Recently it has been sucking at that even. It seems to be going slower, and its not applying even pressure across the board. I will start to mount a 4X8, and the first 2-3' on one side will have serious bubbles in it as if it were only applying light pressure, and by the time it gets to the end of the board, it has skewed the whole board by a couple of degrees.
Do people have these things serviced, or just by a new one? Our model is a Royal Sovereign 54" cold laminator RSC-1400C.
Any input would be appreciated
Once you get the cover off it should be fairly evident what is going wrong. I think it may be a chain similar to a bike chain that raises and lowers the top roller on the left side came loose on ours?!?!
