Flexi outline options issue....?
appropriate1
I use Flexi 22 and have outline options for rounded corners or square corners. When I choose the square corners, they always
have a diagonal 45 degree cut at each corner of each letter, so not square corners. They look that way and cut that way.
Every font, every reboot. Do I need to un-install and reload the whole works maybe?
Bene using Flexi since 1997 with no issue like this. Thanks.
RiXaX
Toward the bottom of the outline dialogue box there are two drop down options. Join Type on the left and Cap Type on the right. On the join type you need to select the square corners.
