Before you chase brands, make sure the right window is film at all. Look along the edge at the frame for a cut line, or try a corner with a fingernail. If there's no edge it's probably etched or sandblasted glass, and no film is going to match that exactly side by side.
If it is film, get swatches of two or three frosts and stick a small piece of each right next to the old one. Check them from outside in daylight and again at night with the lights on inside, because frost looks a lot different backlit. Some of that green your friend sees can be the glass itself too, so test on that window, not on a scrap.
Also the old film has had some sun on it, so even the same product won't look new next to it. Sometimes the cleanest match is redoing both
windows.
