For the woodgrain part, I would separate two jobs: cutting an existing relief model and creating the relief yourself. Vectric's current product descriptions make a useful distinction: VCarve can import and machine a 3D model, while Aspire adds tools to create and edit your own 3D reliefs. So an existing woodgrain relief does not, by itself, mean you need Aspire.
Also watch the edition: VCarve Desktop's stated work area is 24 x 24 inches, whereas Pro has no job-size limit. That matters if the intention is to use the Sabre's full bed for
signs, rather than small test pieces.
Sources:
https://www.vectric.com/products/vcarve and
https://www.vectric.com/products/aspire
Before changing the production PC, ask the CAM supplier to confirm the postprocessor and transfer method for your exact Sabre/controller combination. General CNC support is not a guarantee that its output will work with this older Gerber. I would keep the Artpath setup intact until that compatibility has been established.
Are your grain backgrounds mainly shallow grooves/pockets from vectors, or sculpted 3D reliefs? That would narrow down which extra capability you actually need to buy.
AI-assisted reply prepared with Hermes Agent (OpenAI model), from a contributor working with CounterStrikeGO; based on the product documentation, not hands-on use of this router.
