hard drive clicking?
gabagoo
Started up my main computer and I hear this clicking sound like a clock only faster. Windows loads real slow and now I have it up and running and it has stopped. Am I going to have a failure? I am starting to back up important stuff just in case.
MachServTech
Every time I have had a major HD failure it wad always preceded by a clicking noise....usually the reader arm failing.
Do your backup while you can then don't make the mistake of continuing to use that drive....just replace it...its cheap insurance.
MyShop
yes, more than likely death is imminent. that being said, i have had loud HDDs last for years, but i wouldn't trust it for another 5 minutes.
Letterbox Mike
Yup, back it up immediately, and if possible, don't shut it down until the backup is done. More than once I've had the problem and said "I'll back it up tomorrow", only to try to boot the following day and have a dead drive.
gabagoo
is it possible to copy everything off that drive to a new drive and then use that as my main drive?
also i want to back up my email info, just in case. Where in windows or wherever do I find the actual email files?
SignBurst PCs
It is only a matter of time if it is clicking. Most likely, a short period of time.
If you can get info off, do it now. If you can't, then stick the hard drive in a freezer overnight and then connect it back to the computer with "cold packs" under and around it.
While the drive is still cold, get as much data off as you can. It has save my rear a few times and is worth a try.
MachServTech
Backup Email For Outlook​
Hide All​
Applies to Microsoft Office Outlook® 2003 Making regular backup files of any important data you have is always a good idea. One way to back up e-mail messages is to use the Outlook AutoArchive feature. Archiving means moving messages to an archive folder at regularly scheduled intervals.
Another way to make a backup file, which is described in this article, involves exporting (copying) the contents of the message folder to a Personal Folders file (.pst) (Personal Folders file (.pst): Data file that stores your messages and other items on your computer. You can assign a .pst file to be the default delivery location for e-mail messages. You can use a .pst to organize and back up items for safekeeping.) using the Import and Export Wizard. This creates the backup .pst file. You can then copy the .pst file onto a CD or DVD for safekeeping or to move the data to another computer with Outlook installed.
Back up messages to a .pst file
Important You should not export items (item: An item is the basic element that holds information in Outlook (similar to a file in other programs). Items include e-mail messages, appointments, contacts, tasks, journal entries, notes, posted items, and documents.) that were created in multiple languages or in a language that is not supported by your system code page to a file type that does not support Unicode. For example, if you have items that were created in multiple languages in a Microsoft Outlook Personal Folders file (.pst), you should not export the items to a Microsoft Outlook 97-2002 Personal Folders file (.pst). The latter file type does not support Unicode. Therefore, all items that contain characters in a language other than those supported by the system code page in text fields other than the body of items, such as To, Subject, and ContactName and BusinessTelephoneNumber properties of Contact items, will be interpreted incorrectly and displayed as question marks (?) and other unintelligible text.
  1. On the File menu, click Import and Export.
  2. Click Export to a file, and then click Next.
  3. In the list, click Personal Folder File (.pst), and then click Next.
  4. Click the folder that contains the messages you want to back up. If the folder contains a subfolder that you want to include, select the Include Subfolders check box, and then click Next.
  5. Under Save exported file as, click Browse, and then specify a name and location for your backup file, for example, Mail Backup.
  6. If you back up a .pst file that you have backed up to before, click one of the following: Replace duplicates with items exported Existing data will be overwritten with the information in the file being exported.
    Allow duplicate items to be created Existing data will not be overwritten, and duplicate information will be added to the backup file.
    Do not export duplicate items Existing data will be kept, and the duplicate information in the folder will not be copied to the backup file.
  7. Click Finish.
Other things you might want to do
Now that you have a backup file of your messages, the following are some things you might want to do:
  • Open the data file to see its contents in Outlook.
  • In case anything happens to your hard disk, you might want to make a copy of your backup file using the Personal Folders Backup tool. You can then copy your Outlook backup files to a CD, a DVD, or other removable media. The backup files are exact copies of the original files and are saved in the same file format. You can receive periodic reminders to back up your files.
  • If you have an existing .pst file to which messages are being delivered, and you want to add the messages in your backed up .pst file to this .pst file, use the Import and Export Wizard to import the backed up .pst file. How?
    2. Click Import from another program or file, and then click Next.
    3. Click Personal Folder File (.pst), and then click Next.
    4. In the File to import box, specify the path and file name of the .pst file you want to import.
    5. Click one of the following: Replace duplicates with items imported Existing data will be overwritten with the information in the file being imported.
      Allow duplicates to be created Existing data will not be overwritten, and duplicate information will be added to the current Outlook folder.
      Do not import duplicate items Existing data will be kept, and the duplicate information in the file will not be copied to the current Outlook folder.
    6. Follow the remaining instructions in the Import and Export Wizard.
    Important You should not export items that were created in multiple languages or in a language that is not supported by your system code page to a file type that does not support Unicode. For example, if you have items created in multiple languages in a Microsoft Outlook Personal Folders file (.pst), you should not export the items to a Microsoft Outlook 97-2002 Personal Folders file (.pst). The latter file type does not support Unicode. Therefore, all items that contain characters in a language other than those supported by the system code page in text fields other than the body of items, such as To, Subject, and ContactName and BusinessTelephoneNumber properties of Contact items, will be interpreted incorrectly and displayed as question marks (?) and other unintelligible text.
  • If you just bought a new computer and want to use the .pst file that you backed up to create a new e-mail account, you can reconnect the backup data from your old computer to the new one.
gabagoo
my back up drive is at home so I will leave the beast running until tomorrow. I did a back up 3 weeks ago so it wont be to bad. Backed up current files on cd for now. Outlook not working to well and wont let me export the messages. Where in the computer are they held and I can just save the folder to cd
trakers
I hate OE, but have to do this all the time for others.
Go into OE and look here: Tools | Options | Maintenance | Store Folder
Copy that long ass string (Similar to the below)
C:\Documents and Settings\Nunya\Local Settings\Application Data\Identities\{7BF00AD7-87AB-861A-960F-B95AC898ED6}\Microsoft\Outlook Express
Then close OE. Then goto Start | Run and paste that string in. That will take you to the folder where the relevant files are stored and from there you can copy them over.
Good Luck.
S
scarface
Guest
Yep sounds like a HDD failure. I had this happen a few months ago, Thank god for external HDD's.
2972renfro
If you repalce consider RAID. Depending on how you set it up, if one fails you can pull it out and replace and not miss a beat and not lose any data
Alphonse43
I've just had a WD external drive fail 3 days ago. Fortunately it's the back up, so I can back it all up again from my main PC, and I will now, also back everything up on Dual layer DVDs.
trakers
Our last failure sounded like a metal lathe. It ran 3 days or so like that until it locked up. I took it apart and the platters were frozen SOLID.
Nice.
