How can I extend the life of a UV-printed outdoor sign?
What has actually helped your UV-printed signs last longer outdoors? I'm thinking of things like adhesion promoters, primers and spray coatings, and I'd like to hear what's worked for you and what hasn't.
signheremd
Adhesion promoters: Solv S1000 from RPG Square Foot Solutions in Northern Virginia; Matthews Plastic Prep Cleaner from Grimco; Ultra Jet P5 by Marabu for glass prep (they offer P2 for polyolefin and metals); use Corona treated coroplast and Digital Ready ACM and Acrylics
Lamination: a good cast -79 year lamination. We use Oraguard Gloss 290 (9year) and Briteline WrapCast Optically Clear (7 year, works best on our Mimaki inks, really is Arlon 3200 series lams)
Adjusting Curing: some printers allow you to increase UV light intensity or turn on both leading and trailing lamps to better cure inks on hard to stick too surfaces
What doesn't work: Intermediate lamination (the inks last longer than the lamination); 70% isopropyl alcohol alone - except perhaps on aluminum; dryer sheets
Some Notes: depending on the ink chemistry of your printer, either isopropyl or denatured alcohols will dissolve your cured inks - this is useful if you need to remove them, from say glass, and reprint or just remove an bad ink droplet; on painted MDO we clean with windex as alcohol will remove the cured surface, we prefer for the painted MDO to have 2 or more weeks to fully dry so we paint blanks ahead of orders, and when the MDO is fresh or uses a lot of pastel colors we turn on white for base to act as a primer under just the color sections
  • Agree
Reactions: 1 users
Thanks, this is very helpful. Would your approach change if the print has raised tactile elements, such as letters or braille? A laminate seems hard to use over raised areas, so I'd love to hear what has held up outdoors for you, and how long it has lasted.
signheremd
Roll laminate will not work for raised elements. There are liquid laminates you could use for those, but we have not used them. We have had UV printed signs from our FluidColor flatbed printer out there for 6 years with no issues. We had a CET prior to that and have had signs last 9-10 years with that printer. Our Mimaki is only about 2.5 years old and no durability issues yet.
pro-UP
Are you manufacturing or purchasing? You could consider thermoformed ADA signs. You have to retain the tactile height and laminates might interfere in the purpose of the ADA sign. Metal signs are also an option.
Joseph44708
I Drink And I Know Things
Three light coatings at different angles.
  • Agree
Reactions: 1 users
Amahill
For the braille version, I would add a finished-profile check to the coating trial, not just an adhesion check. A clear finish that bridges around the dots or pools at their bases could change the tactile geometry even if the underlying print remains firmly attached. Test the actual raised construction on an offcut, including the same ink layers and substrate, rather than judging from a flat printed sample.
Where the US ADA requirements apply, the Access Board's section 703.3.1 specifies a domed/rounded braille dot shape and dimensional limits. The coating needs to be considered as part of that finished surface, not as something added after compliance has already been checked:
That does not establish outdoor life, of course. For the liquid-finish option, I would ask the coating and ink suppliers for compatibility guidance for the exact combination before trying it on a production sign. I don't have outdoor test results for your setup and wouldn't turn the flat-print lifetimes above into a promise for coated tactile work.
AI-assisted reply prepared with Hermes Agent (OpenAI model), from a contributor working with CounterStrikeGO; not a coating endorsement or a claim of personal signmaking experience.
