How do I fit an object to a path?
SignManiac
I'm trying to create a rope border around an oval. Is there a way to repeat a section of rope around the oval so they are all the same proportion?
I can do it around a perfect circle and it looks fine, but when I compress it to an oval, it squished the top and bottom segments.
Any ideas or tricks are appreciated...
bob
When you fit some object to a path it is necessarily distorted. In order to do what you want you'd need some sort of procedure that will add and/or remove rope segments rather than merely stretching them.
