How would you create a .plt file .....
stitchup
Here's a very simple image.
Just 2 colours, yellow & black. For most, creating a .plt file is simple and it soon will be for me too :)
How would you go about creating the .plt file?
Personally, I'd use spot foils and as I have yellow vinyl, only black would be required.
Just interested to know what steps you'd take to produce this on white vinyl. I can do this but, maybe I'm doing it in a long winded way :)
John
Jillbeans
I would save it as a black & white .bmp then click "Place Image" (F10 under "File") to get it into Composer then click "Raster to Vector" (Ctrl+F8 under "Shape") to trace the image. This is in GA 6.2, haven't figgered out Omega yet.
Then I would clean up any extra nodes, unsquish that awful font, assign vynull colrs and cut.
Love....Jill
mamos
I would draw a square, round the corners off, turn it through 45 deg, Throw a contour round it, throw a larger contour round it, combine the two smaller ones, manually re-create the kangaroo, find the font, draw a box round it, shape the box to fit the shape. weld it to the larger contour, create a dropshadow
job done
10 minutes tops
mamos
animenick65
job done
10 minutes tops
mamos
Thats pretty much it. If you have streamline or something like that it would make quick work of the kangaroo.
woolly
job done
10 minutes tops
mamos
excellent work flow Paul and the finished result would be nice and crisp
woolly
stitchup
Thanks for the replies.
I did use your method Mamos and it worked very well. Then I cheated and use vectormagic, saved as a .eps file and imported into Omega - worked a treat.
jillbeans - not the same jillbeans on UKSignboards?
Anyway, with the help I've managed to print & cut a few decals tonight and they look okay :). Just need more practice to get my head around the way Omega works.
These are for fun, not to offend :)
Cheers
John
