HP 365 Latex Printer, print, laminate and contour cut
Eurodesign
Eurodesign
I have an HP 365 Latex printer, the printer prints fine but when I print with crop marks, then laminate and then contour cut, my new Roland Cutter GR2-640 does not want to read the crop marks. I am using Flexi sign Production manager Subscription which came with my printer. I like to design my graphics in Corel Draw, assign a contour cut and import it then into Flexi Production manager. With my old vinyl cutter Roland Camm-1 pro I had not problems to cut after the fact, he read the crop marks perfectly, but my new one (Roland Cutter GR2-640) does not at all.
Does anyone have the same problem and got it solved?
Or is there a different Rip software available?
MarkSnelling
Mark Snelling - Hasco Graphics
You've got to be missing a step or something. I'd hit up whomever you purchased the Roland plotter from for help. I've got dozens and dozens of customers who print+laminate+cut all day, every day. Or call Roland support yourself....they can walk you through the process.
Manevitch
HP Latex Application Product Specialist
What happens if you don't laminate? Is the laminate you're using UV-protective? I've had issues in the past with Graphtec plotters not "seeing" marks through certain UV laminates. The easiest way to test is to try to cut an unlaminated print; if that works but laminated does not then it's likely that the sensor can't work properly through your laminate.
Easy fix: place a small Post-it over each mark. Make sure the adhesive edge will hit the laminator first so it doesn't wrinkle. Then laminate your print. Once it's out, take an X-acto and carefully cut around each Post-It and pull it off. Now your marks will be unlaminated, and the plotter will be able to use them properly.
ozpall
i was having a similar issue with my mimaki 160, after lamination the laser would not read the marks, i started masking taping the marks and after lam i would cut out the masking tape, not very productive.
i figured the gloss from the lam was throwing off the laser so i started to put a towel over the laser to make it dark and that solved all my problems ever since.
hope this helps.
Pinecrest
Today we had issue with our graphtec plotter , also use flexi subscription. , we called flexi support they downloaded a few of the latest recent updates via teamviewer and after that we were good to go....
