HP 365 - Yellow Issue
Cheeses
Hey everyone. I've been lurking on these forums for quite a while and usually find whatever answers i need with a little research.
However, i'm having an issue with my yellow ink and wanted to see if anyone had any ideas before i just start replacing printheads. Everything had been running fine until a week or two ago when i needed to print some posters. These are a common poster that i print regularly for a customer, but all of a sudden the yellow is barely there. Blues are purple, the light yellow/beige background is almost gray. I was running pretty low on yellow ink and thought that could have been it. Replaced with a new yellow, as well as a brand new OP as it was out of date. Still had the same issue. I also tried different stocks in case it was the new roll of poster material.
Printheads are on the older side, but have only fired about 500ml of ink. I tried to soak/clean with some distilled water incase it was clogged and it's still the same.
Is there anything else i should try? Should i just go ahead and order new printheads? My boss is kind of a tight ass, so every time i make a purchase i get grilled lol.
Ronny Axelsson
You say you lost yellow after running low on ink, and it didn't come back even after replacing the yellow cartridge, is that correct?
I have had similar issues after letting ink cartridges run empty or very low before replacing, and the only fix I found, unfortunately, was to replace the printheads.
Maybe they can be cleaned in some way but I didn't manage to get it right and ended up buying new heads.
Now I try to keep an eye on it and replace cartridges when they go under 20 ml, or something like that, to be on the safe side.
