Question i1Studio pro, profiling on non-paper material
NathanR
Hey folks,
I was wondering if anyone has experience setting up printing profiles on things other than white paper using the i1 Studio Pro spectrometer and software?
In my case I'm trying on raw wood and colored leatherette on a Mimaki Jfx200.
I did successfully run a profile with off-white leatherette and a sheet of wood with white primer, but when I try to run the color scan on plane wood with no primer the software gets stuck trying to calculate the next steps despite the scanner indicating all the scans where good.
I do realize this might be asking a question similar to "how can I fly with my arms and cardboard" but I figured I'd check and see if anyone has experience with this.
Pauly
Printrade.com.au
Yep wont work.
to understand how CMYK works, it's subtractive as when ink is layed on the media, it always gets darker (subtracting light) , so you need a whitepoint to begin with.
having a "whitepoint" that's a different colour will not work, as for starters the software will get very confused why the whitepoint is brown.
Realistically you cannot create an accurate icc profile for wood. you just have to use a generic icc profile. And you'll never get accurate colours printing on something that's not white to start with.
Create your own generic profile on paper, or wood with a white primer etc. and use that.
Christian @ 2CT Media
Yep wont work.
The other issue you will run in to is, wood being natural will have a different base color from sheet to sheet.
NathanR
Ah, That makes sense.
Kinda figured it was a long shot of it working in the first place.
I appreciate the help.
