Adam Vreeke
Knows just enough to get in a lot of trouble..
So I am having some trouble with ink adhesion on our JFX200-2513EX running LUS120 ink. Here is the deal; it is .015 styrene, double sided flood color. Since they are cut into 1 x 3 pieces with shared cut lines. So I do a heavy score and break the pieces apart. This method worked very well with out harder LH100 ink; however, with the softer more flexible ink of LUS120 I am having trouble were the ink on the back side will flex and tear ink off of pieces on the back side.
I have tried varying ink percentages of the machine Primer (PR-200) 20%, 35% 40% 50% 75% and 100%, with different irradiation levels (just 100% and 130%). I have tried these with varying lamp positions 65/65, 65/0, 90/0, 0/0, 90/90. Everything I seem to do with primer leaves the CMYK level extremely tacky, and I can just wipe away the ink with my finger.
I am just about to try different levels of a white under base just for funsies now, but I am getting to my whit's end with this. Has anyone had any luck with machine primer on styrene? If so are there good setting you have had success with?
I would normally hit this with our machine with the LH100 ink as I have ran this job multiple times on there with no issues, but that machine is booked solid for about 3 weeks. I am also new to machine primer, so I am wondering if I am missing something, I have been treating it about the same as clear ink with lamp positions and such.
EDIT: The UV lamp glass is free of fog.
