Installed Font, can't find in Flexi??
I installed the Souvenir font for a project I'm working on, it's a True Type font...put it into the windows/font folder and can't see it in the Flexi program, tried dropping it into the Flexi/FSFonts folder but notice there are no True Type fonts in there and it didn't work anyway.
Any idea what the deal is? I've opened and closed Flexi a dozen times with no luck...it does read from the windows font folder as well doesn't it? Any help is much appreciated.
I have Flexi Pro 8.1 V1
Thanks.
Fred Weiss
Usually an open job will not see a newly installed font. Closing the job and reopening it will usually correct the issue. A relaunch of the program is not normally needed.
You might want to check to see how many fonts you have installed in your Windows Fonts folder. Depending on your system resources, fonts will start not showing up in menus typically between 500 and 1,000 fonts installed.
