JF-1631 strange error
LaserMan
Where to start.....
I changed out a head and when i powered everything back up, i burnt one of the ribbon cables (from the mengta head i replaced). I replaced that and got the error message;
System Halt (1)
11d: PCB SLRLY_F1
Figured out it was one of the fuses on the PCB Station. We soldered on a new fuse and use a volt meter and it read that it was working. So, i put the board and cables back in and then i got a weird message i've never seen before.
First screen that popped up said
Systam Halt
PCB Station
That lasted about 3 seconds on the screen, then this popped up.
133: PCB State
PIO: Slider ok
But it's all frozen. I can't do anything. Has anyone else every seen this, or know how to fix this?
LaserMan
I need to edit the last two error messages.
SYSTEM HALT (1)
133: PCB STATION
That's followed by
133: PCB STATION
PIO SLIDER OK
Thoughts anyone??
LaserMan
Still have the issue.
Someone mentioned that it could be the Station PCB board. Said it's underneath where the inks are. I opened it up and there is a board that says Station E400579. I can't find that online anywhere?!!?
Ryden5x
did you check the connector connection of the table IO PCB?
also did you check the connector connection between table IO PCB~main PCB
