Big Blue
Swaped back to Mimaki inks from 11-10 inks... the magenta Black and Yellow all work fine, but the Cyan wont print. I used a syringe to draw the ink to the dampers and filled them up, and they stafy full, the also you can see ink in the lines all the way to the dampers, so I know the ink is present, but when I print a test draw I get nothing at all.... Did the whole cleaning process with the cleaning cartridges first and now I'm having this problem... could I have a clogged Jet, it did sit for about a week waiting to switch inks. Could hit a home run with the Boss If I could fix this myself, instead of calling a tech. Any Ideas as to what I could do, or who I could call....
. Had a problem one time, printer had been working fine and nozzles started dropping in one head, changed the damper and then nothing.
) change the capping station, still nothing. At the time the machine was 5 years old and I just knew it was the head, tech friend of mine said to try the pump first,
