Kala Arkane 1650 Problems
Alphaken
Hello my fellow large format peeps!
I have in my shop a 2-3 year old Kala Arkane 1650 laminator that we got brand new. It has been working flawlessly since about a week ago. The problems im having is a few different thing.
1. The output roll does not spin anymore to collect whats being laminated.
2. Cooling Fan does not want to work.
3. When trying to encapsulate with hot lamination it wrinkles at the end of the print. Does it with poster paper, bond, and vinyl. I have tried to calibrate it many times as well as different pressures and speeds.
4. Single sided cold lamination is completely fine doing harder substrates
What should I be trying before calling in a tech to come and look at it?
Thanks Fellas!
MarkSnelling
Mark Snelling - Hasco Graphics
1) I wonder if the teeth on the end of the take-up shaft are worn? Since the shaft is tied to a motor via chain, then maybe try swapping the shaft out for a different shaft with more of a tooth at the end for better grip?
2) I can't help you here
3) Where do the wrinkles happen? Everywhere or primarily down the middle? If it is primarily down the middle, then back the pressure down so there is only 1 light on in the pressure guage
4) What happens when you laminate cold onto a print without a substrate?
You are welcome to call me tomorrow. I am on an airplane most of the morning and land at 11:30 EST. If I can't help over the phone, I can send you in the direction of people who can fix it as there was a significant change in how Kala does business in the US market.
