L25500 "bleeding" from right side
I have noticed my L25500 is leaving a small puddle of ink under the right side... It is running down the right leg to the floor. Any ideas for what this could be? It isn't the waste tank overflowing, I checked that.
Aklaim
Check the funnel to see if it's clogged. Mine did this a few years ago and all of the ink that it was spitting out was running through the inside of the machine because it had nowhere to go. It was a pretty lengthy fix to get it all cleaned up.
How do I get to the funnel? Can I get to it through the door on the right side or does the right side cover need to come off?
Morkel
The only way I've been able to access it is when I go through the Printhead Cleaning Kit swap, or Ink Maintenance Kit. Not sure if you can do this process to access it, but not actually change it (as in the printer might detect that it hasn't been swapped and stay in a holding pattern). An Ink Maintenance Kit is cheap, so it's probably worthwhile just doing that - it'll replace the funnel & the hose.
Turn printer off. Pull carriage out to the left into printing zone. Under where it was you will see the maint cartridge and the ink funnel. These should be replaced when you replace the waste ink tank. You should be able to easily tell if that is the issue. It could also be the little vagina looking outlet on the tube that goes to the waste ink bottle. If it's something in between your going to have to take the side and back of the printer off.
