heres what my manual says....
SE Code: 63:05 - The raster data does not arrive quick enough
Problem Description:
The raster data of the job is not arriving quick enough to assure correct printing conditions.
Corrective Action:
• Check that a 1 Gigabit Ethernet Card is being used, make sure it is correctly installed. If necessary,
replace the Gigabit Ethernet Card. Do not printer via a hub, as the communication is not quick
enough.
• Check the RIP for any error messages. Check that the
computer with the RIP application is
functioning correctly. Check the HDD is not full, does the
computer need to be defragmented etc.
• Check the customer is printing from a
computer with the minimum system requirements, check the RIP
documentation for details
• As a workaround the customer could reduce the resolution of the job, or print the job as mulitple
files.
I would check your cable that connects the RIP to the printer...look for fraying or loose connections. Try a brand new ethernet cable. You may also want to run a system utility like IOBIT Advance System Care (free) to clean up and optimize the RIP station
