laminator mounting problems with Coroplast
anotherdog
I have a Royal Soveriegn cold laminator, I'm okay with just about anything with the exception of full width (48 inch) mounting adhesive on Coroplast.
there seems to be a slight gap at either end of the top rollers, this doesn't quite make an airtight seal with the adhesive and Coroplast, I'm getting bubbles.
If I take the rollers to the next thickness down I'm crushing the cells.
The Laminator is only 2 years old, so I don't think I have banana rollers.
Anyone else seen this?
Sticky Signs
The rollers come with a slight crown from the manufacturer. It's not a defect. Are you centering the boards on the laminator?
anotherdog
the boards are centered. I'm thinking maybe I need to feed something with it to build up the thickness yet not thick enough to crush the Coro.
The nature of this laminator is it has about 6 thickness presets.
Thank you for letting me know about the slight crown. I did suspect it.
MikePro
when i use my laminator to apply sheets of printed graphic to coroplast.... i dial down the pressure so that its just barely enough to grab and pull the sheet thru. Seems i always get bubbles at higher pressure setting.
