Leaking ink
Bigmoreno1
I have an epson f2000 that is leaking white ink from the back of the machine, i ran a nozzle check and none of the white channels are working, although the colors are working fine,, i was hoping someone knew what could have caused this, is it worth fixing? I purchased this machine used.
JenHess
Have you tried checking the lines to see if connected properly or there may be a hole in the line in which case you may be able to just replace the line.
Also check the dampers they may also be a culprit.
Superior_Adam
that could be a few things. More than likely the white pump in the back behind the cartridges. A tech can come fix it. You would have to call Epson and they will get you set up with decision one where they will quote the job.
