P Wagner
So the 360 prints under a minute per foot In 600dpi 10 pass BiDi?
The spec sheet says 151 sq ft/hr which is 50% faster then the L26500 @ 98 sq ft/hr
Pass counts are different on the 300 series than the 200 series. This is due to the addition of the Optimizer into the new inkset, which allows for reduced pass counts. On the Latex 360, 8 pass is the equivalent of 10-12 pass on the 260. Print speed is rated at 183 sfph at 8 pass on the Latex 360, which is not quite double the speed of the 260. Carriage speed has been increased by 50% on the Latex 360 which also helps with throughput increases versus the previous models.
At 6-pass mode the throughput increases to 248 sfph, and banner medias generally work well at that pass count. I even have some users running outdoor banners at 4 pass (at a blistering 334 sfph) on the Latex 360, though inks must be aggressively restricted to make this speed work well.
